Orbi WiFi 7 RBE973
Reply
Change Ip Extender Wifi Ex 3700
Onecool94
Hi,
I have in the same house two wifi extender Ex3700 and EX6250.
The problem is that they have the same ip 192.168.1.250.
So if I try to change some option i can access only a wifi extender.
There is a metod to change the ip of exstender?
Thanks a lot.
Model: EX3700|AC750 WiFi Range Extender Essentials Edition, EX6250|AC1750-WIFI MESH EXTENDER
Message 1 of 2
antinode
Guru
Re: Change Ip Extender Wifi Ex 3700
   That's the default IP address for one of these devices, but it should
get a new/unique one (using DHCP) when it's connected to a router.
> There is a metod to change the ip [address] of exstender?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "IP address".
But you shouldn't need to do anything about it manually.  The manual for
the EX6250 provides more details.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 407 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
