Reply
Changing DNS in router settings
Railroader
I need to know how to change my IPV6 DNS server setting to the settings suggested IPv6: 2606:4700:4700::1111 and 2606:4700:4700::1001
Thank You
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 6
microchip8
Master
Re: Changing DNS in router settings
use four zero's as replacement for the double colon
2606:4700:4700:0:0:0:0:1111
Routing: NETGEAR RAX43 - Firmware: v1.0.11.112 (1 Gbps down, 50 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 6
schumaku
Guru
Amazing - Netgear claims to support IPv6 but fail properly parsing IPv6 (correct) addresses.
Message 3 of 6
Railroader
Firmware Version
V1.0.1.64_1.0.1
Model: R6700|Nighthawk AC1750 Smart WiFi Router,R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 4 of 6
Railroader
on my routers advanced config screen, ipv6 lan setting, there appears to be no option for inputting a primary and Secondary address. More hand holding required I guess. Thanks
Message 5 of 6
Railroader
I did not see much info on how to input  server settings for IPV6. Thank You
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1090 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
