Orbi WiFi 7 RBE973
Reply
Choose IEEE 802.11 mode
Israel-ARP
Hello everyone,
I am using the router for academic research,and I need it to use only 802.11b mode. How can I configure the router to do that?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 7
Accepted Solutions
JamesGL
Master
Re: Choose IEEE 802.11 mode
Hi Israel-ARP,
Channel can be changed under the wireless settings. NETGEAR firmwares don't have options to select 802.11B.
Message 6 of 7
All Replies
JamesGL
Master
Hi Israel-ARP,
The lowest mode that the router can be configured is 802.11G byt setting the mode to upto 54mbps.
Message 2 of 7
Israel-ARP
Ok... But I need more than that.
I want to configure its mode to 802.11b. And i just can't find a way
to do that... is that possible at this router?
Message 3 of 7
JamesGL
Master
Hi Israel-ARP,
This is not possible with the firmware of this router. As what I have mentioned, the lowest mode you can configure the router is the 802.11G.
Message 4 of 7
Israel-ARP
So can i change the firmware? Which firmware will give me this ability?
I need also the ability to change the channel...
Message 5 of 7
JamesGL
Master
Hi Israel-ARP,
Message 6 of 7
JamesGL
Master
Hi Israel-ARP,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4295 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
