Reply
Client mode openvpn
teros
Client mode openvpn
Hey,
Looking at getting this unit couple of q's:
Does the unit support client mode i..e connecting to an openvpn server from the unit?
Does it forwarding of traffic based on port i.e. Bittorrent traffic to vpn other traffic port 80 etc. through the internet port?
Transmission BT server at all?
Message 1 of 2
Fairytail
Virtuoso
Re: Client mode openvpn
The unit only have the openvpn server feature. You need to install the client on the computer if you want to connect to the router's VPN server. It does not have a feature that will automatically adjust for applications like Torrents. You need to manually open the port you set up for the Torrent. Just go to the port forwarding option to open that certain port.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 8637 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
