- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Compatible routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Compatible routers
I purchased a Nighthawk CM1100 Modem. I am trying to find a list of compatible routers (the product spec sheet only has the AX8 8 Stream wifi router listed. Are there other wireless routers that are compatible? I didn't want to spend the amount listed for for AX 8. Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Compatible routers
Any decent router should work just fine. They all should connect with the modem just fine. No special magic required. Very hard for a vendor to keep a list up to date.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Absolutely. Find one that fits in with your budget and needs.
There is no reason why you should stick with Netgear – some people would say that you should avoid it – but some of us find that it is easier to stick with one brand because then you can get used to how they work.
Start here:
New Nighthawk Tri-Band AX12 12-Stream WiFi 6 Router
Plug in your needs, and then see what the reviews and comment here tell you.
If you want a personal recommendation, the R7800 has a lot of fans. Reliable and basic. A bit old, but in this area newest is not always greatest.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40VUser | Count |
11 | |
10 | |
5 | |
3 | |
3 |
