Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Confict with Uverse DVR and R700?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-01-13
05:27 AM
2014-01-13
05:27 AM
Have an issue occuring with internet and one TV. Configuration:
1. Multiple UVerse HD TVs - one we are having issue with is our "Main" TV - with a Uverse HD DVR. DVRs connected to "signal" using ethernet cable
2. Uverse Internet - our "service" comes into the garage, where we have some home audio distribution panels. Goes through a 20 port router then distributed throughout the house. One ethernet connection goes to a Netgear R700 Router connected to our "wired" home computer, and this router sends out our wireless signal.
All had been working fine, then started having issues. The main TV will "freeze" for 4 or 5 seconds at a time. Others do just fine - no freezing at all, even at same time the main TV is "frozen". We have gone through technical support several times, and rebooted the DVR. Post reboot, will be better for a while, then start freezing again
Concurrently, having internet coonnection issues. Internet will work fine for a while, then will stop working, and the router will have to be totally reset. Message will appear that the router has been given a new IP address so as not to conflcit with a device on the network. With internet back up, TV starts freezing.
If that TV on and trying to use internet at same time, TV will freeze off and on, and internet connection will lose connection.
I have to think that these issues are related and must relate to the two devices (DVR and R700 Router) having some sort of IP address conflict. Is that possible/likely? How to correct?
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
2014-01-13
04:49 PM
2014-01-13
04:49 PM
Re: Confict with Uverse DVR and R700?
You need you use R7000 as access point and not router with your setup
http://kb.netgear.com/app/answers/detail/a_id/23814
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
VPNCASESTUDY.COM
June Mizoguchi-
Message 2 of 2
