jashobhit's avatar
jashobhit
Follower
Mar 23, 2021
Configure C6900 as repeater
Hi,
I have a C6900 which I was using. Now I changed my ISP and new one gives modem. I now want to use my C6900 as repeater but I do not see an option in advanced settings to do that.
Can it be configured as a repeater/ extender? If yes, any guidance on how to do so would be appreciated.
BR,
SJ
1 Reply
  • > Can it be configured as a repeater/ extender? [...]
       Not in the usual meaning of those terms.  It should be possible to
    configure it as a wireless access point.  That requires an Ethernet (or
    equivalent) connection to the main router.  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
    That's written for a Netgear C6300-as-WAP, but the steps are about the
    same for any other router (any make/model) which lacks a one-step WAP
    option.  (Especially similar for another Netgear Cxxxx.)
