- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Configure two Nighthawks behind a Ubiquity edge router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I will be installing 2 Nighthawk R7800 behind a Ubiquity Edgerouter X. The first Nighthawk will provide wireless SSIDs and should have DHCP disabled (Bridge Mode or just disable DHCP). The second Nighthawk will be placed in an area that currently has a poor wireless performance.
What is the best way to configure the Nighthawks.
Thanks for your help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
One some of my routers, in ap mode, you leave it plugged into the wan port. On others, you have to move it to the lan port. you can check your specific devices settings and it'll show you. I believe for the R7800 you can leave it in the wan port.
https://kb.netgear.com/000061927/What-is-the-difference-between-router-mode-and-AP-mode
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Configure two Nighthawks behind a Ubiquity edge router
If they're both hardwired in, you should just be able to place both in access point mode. That disables the dhcp and lets the ubiquiti run the routing portions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the fast reply.
To make sure I have this right. Plug into a LAN port on each Nighthawk and nothing in the wan port? Will AP mode let me set the SSID and pass phrase? Just use the same settings on each Nighthawk?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. You've be a huge help and it is greatly appreciated. Have a good day.
