Reply
Connect WPS wireless connector to R7000 (no WPS)
poconnor
Hi all,
Title says it all really.
I've switched to the R7000 from my ISP standard-issue router. For my TV set top box I have a Sky Wireless connector that normallu hooks up the WiFi via WPS. With the R7000 not having a WPS button I obviously cannot do this so wondered if anyone has any idea about how I can get the wireless connector to hook up to my new wireless network?
Thanks.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Re: Connect WPS wireless connector to R7000 (no WPS)
@poconnor wrote:
With the R7000 not having a WPS button I obviously cannot do this ....
The button is well disguised.
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
See Table 1. LED and button descriptions. At the bottom WPS button with LED.
Also check the section Use the WPS Wizard for WiFi Connections.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 7813 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
