Reply
Connect to internet
The_Judge11
Follower
Connect to internet
I have just purchased an R7000 but cannot get it connected to the internet via netcomm NB6PLUS4W modem/router
I have a static IP.
Any suggestions?
Message 1 of 2
RogerSC
Virtuoso
Re: Connect to internet
Don't know if you're aware that there shouldn't be two dhcp servers going in your network, or double NAT'ing. You should put the Netcomm modem/router into bridge mode so that it isn't doing NAT and giving out DHCP addresses. Then use your R7000 for both router and wireless functions. If you can't get the Netcomm into bridge mode, then use your R7000 in Access Point (AP) mode. Then your Netcomm will be doing the NAT and DHCP stuff, and routing, and the R7000 will just be a wireless AP.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1730 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
