Reply
Connected but no internet.
GregerN
Tutor
So I use ethernet and suddenly, the internet dropped and started not working. It says that I'm connected but it has no internet.
What it says in Netgear genie: ladda ned (1).pngScreenshot_2.png
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
myersw
Master
Re: Connected but no internet.
The Internet screen shot shows the router is not getting a IP address from the ISP. First thing I would do would be to power down both the modem and the router. Then one at a time, power up the modem and wait for it to stablize then power up the router. You should get a connection now. If not look at the modem lights. Do you have the normal lights, like showing the link to the ISP is active? Issue you have could be ISP related.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 635 views
  • 0 kudos
  • 2 in conversation
Announcements
