Reply
Connecting Netgear Nighthawk 2300 Smart wifi Router to Att modem
rparikh213
Has anyone had any issues connecting the router to an AT&T modem? I keep getting stuck at the final step and it asked for Static IP Configurations.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Guru
Re: Connecting Netgear Nighthawk 2300 Smart wifi Router to Att modem
ATt devices aren't known to function well with most router because ATT tends to give out modem/router combo devices with poor implementation of passthrough/modem only mode.
What specific modem device do you have for att?
If its a combo device, most have had success with placing their routers in AP mode. you lose some functions of your router by being in AP mode.
ap mode-Access point mode
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
rparikh213
I have a Arris BGW210700 Modem/Router Combo
Message 3 of 4
Guru
I would try the router in AP mode.
You can try the arris in passthrough.
https://forums.att.com/conversations/att-internet-equipment/strict-nat-bridge-mode-what-is-ip-passth...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 473 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
