- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting R7000 to WiFi Signal in an RV Park
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your response. I'll probably buy the equipment needed to help ensure that I get a stronger signal. I appreciate you taking the time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting R7000 to WiFi Signal in an RV Park
Your first problem is a weak wifi signal. The only way to fix that is to use a directional antenna. (A wifi extender would not be practical in your situation.) A directional antenna is easy enough to build, if you're willing to try it:
https://www.makeuseof.com/tag/how-to-make-a-wifi-antenna-out-of-a-pringles-can-nb/
Or you can pick one up on Amazon or Ebay. Next you need to get that signal into the WAN port of your router. For that you'll need a wireless bridge adapter. Lots of them on Amazon/Ebay and other sites selling electronics. Ensure you pick one that can accept an external antenna
This will greatly improve your connection to the internet, but you should recognize that in an RV park, a _lot_ of people will be connecting to the wifi and that means overall service will likely be degraded.
Good Luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
