Reply
Connecting multiple AC 3000's
GAD21
Follower
Is it possible to wirelessly connect a Nighthawk XS6 to a Nighthawk AC 3000 that is connected to the internet?
Message 1 of 2
Re: Connecting multiple AC 3000's
AC3000 ands XS6 are not reliable guides to model number. Many devices come with an AC and XS tags, but they essentially labels that Netgear, and other brands, attach to hardware to describe wifi speeds.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It is usually easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 253 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
