Orbi WiFi 7 RBE973
Reply
Connecting n300 to ac2400
Jugskid
Follower
Can you connect an ac2400 nighthawk router to a n300 adls+2modem router
Message 1 of 2
Re: Connecting n300 to ac2400
Neither of those is a model number, so is if hard to provide a definitive answer.
ac2400 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number. N300 is the same sort of label, albeit one that is even older.
What do you mean by "connect"? You can connect many things, but it depends on what you want to do.
Is the modem/router there to connect you to the Internet? If so, you should be able to put a router behind it. But how you do it depends on what these things are.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 269 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
