Discussion stats
  • 5 replies
  • 1401 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Connecting to att u verse router
Trying boost my wifi plug in the with the ethernet go signal but getting authentication error cant connect need help
Model: R6900v2|Nighthawk AC1900 Smart WiFi Router
Message 1 of 6
Highlighted
Re: Connecting to att u verse router
I don't understand the problem.
What does this mean?
@Jason1413 wrote:
Trying boost my wifi plug in the with the ethernet go signal ..
What wifi plug? What Ethernet go signal?
Is the R6900v2 in your footer the Netgear hardware you are using?
What is the model of the att u verse router?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 6
Highlighted
Ok I connected my nighthawk to the uverse router with the ethernet cable. All of my lights are lite up but wifi is flashing, and I cant connect to internet with the nighthawk. Uverse router is a NVG510
Message 3 of 6
Highlighted
The NVG510 looks like it is a modem/router. So your best bet is probably to find the manual and work out how to put it into modem only (bridge) mode. Otherwise you will have two routers on your network, which is likely to cause problems.
Just another user.
Message 4 of 6
Highlighted
I'm a novice at this, but that's what I'll try next.
Message 5 of 6
Highlighted
Sensei
> [...] put it into modem only (bridge) mode. [...]
   Or, configure the R6900v2 as a wireless access point.  Visit
http://netgear.com/support , put in your model number, and look for
Documentation.  Get the User Manual.  Look for "Use the Router as a WiFi
Access Point Only".
Message 6 of 6
