Reply
Connecting two routers via eithernet cable?
Raccoon11
How do I setup up two nighthawk routers that will be connected by cat 6 eithernet cable about 300 feet apart in two buildings?  I want to use the same satellite model for my barn?
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
antinode
Guru
Re: Connecting two routers via eithernet cable?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Use the Router as a
Wireless Access Point".
Message 2 of 4
TheEther
Guru
You'll want to set up the second Nighthawk as an Access Point, although it's a bit overkill to be using a Nighthawk. Enable AP mode under advanced settings.
Message 3 of 4
Raccoon11
Thank you.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 331 views
  • 0 kudos
  • 3 in conversation
Announcements
