Reply
Connecting
FN_JW22
Connecting
I’m trying to connect this to a PS4 in a different room to the modem. I have calibrated the router but for some reason I can’t get it to connect. When I go on the app it says that the internet is offline. Does it always have to be wired to the modem?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 6
Guru
Re: Connecting
What modem do you have?
If its a modem/router combo device, then you could put the R7000 in bridge mode.
but if its a modem only device, the router does need to connect to the modem
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 6
FN_JW22
Re: Connecting
I just have a basic sky router. What modem can I get to have bridge mode?
Message 3 of 6
Guru
Re: Connecting
what "basic sky router" is it?
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
Message 4 of 6
FN_JW22
Re: Connecting
I’m not sure exactly what router it is to be be honest
Message 5 of 6
Guru
Re: Connecting
If you look at the label on it, it should have a model.
that'll tell us if its a modem, if its a modem/router combo device, or what it is exactly.
If its a combo device, then you could setup the R7000 in bridge more or even use it as a repeater
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 79 views
  • 2 kudos
  • 2 in conversation
Announcements
