- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connection to Virgin Superhub3
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have connected my Nighthawk R7000 to the Virgin Superhub in Modem Mode, but instead of getting the 350mbs I should have I am only getting 200mbs via the router. What have I done wrong can anyone help please
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connection to Virgin Superhub3
Have you powered OFF the ISP Modem and NG router for a good full 1 minute then back on with the modem first then router?
Wired speed testing?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to diable Armor, Access Controls and Traffic Meter on the router prior to testing.
Last resort would be to try a factory reset on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MossKeane I take it then that Virgin didn't supply you with one of their routers? If they did, have you tried using theirs instead of your own?
