Reply
Connection with printer lost (R7000, 1.0.9.26)
NathanNL
Since 1.0.9.26 the connection between my Brother DCP-J5552DW and the network seems to have failed. Reconnecting doesn't work, except that pending print jobs will get through during the setup, but not after the setup has been completed.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Guru
Re: Connection with printer lost (R7000, 1.0.9.26)
Is the printer using a wireless or wired ethernet connection?
Its recommended to set a Static IP address ON the printer, 192.168.1.55 or .52 thats out side of the routers default IP address pool. 192.168.1.100 to .200. You can set this pool on the router up as well.
Try setting WPA2 and AES on the router if the printers using wireless.
Try setting manual channel 11 as well.
Ensure 20/40Mhz coexistence is enabled.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 4
NathanNL
The printer has a static IP address.
I have downgraded the firmware back to 1.0.9.18 and now the connection has been restored.
Message 3 of 4
Guru
Glad it's working again.
Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 430 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
