- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Constant Disconnects - Netgear R6400 v2 - Router Mode - .71, .75, .80
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello!
I have experienced an issue with my Netgear R6400 (v2) in Router Mode. It works on reboot for a few minutes. Then it disconnects and the Nighthawk app reports it as offline if I check there. I have tested this on three different firmwares (10.0.71, 10.0.75, 10.0.80) and the issue persists regardless. I live in an apartment building so there are other routers present throughout the building.
Is there something I don't know about with the set-up that may alleviate this? Or is it most likely just a faulty hardware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Constant Disconnects - Netgear R6400 v2 - Router Mode - .71, .75, .80
Does it self reboot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It does not. Once I notice the disconnect, I perform a reboot, and it works again for a short time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What modem/gateway is the router connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's plugged directly into a wall outlet. Our apartment building has managed internet service with a provider called SingleDigits.
I'm not sure how to check the details of the gateway. But if it's something I can pull from the router admin page or my command prompt window then I will check it.
When other devices such as video game consoles or PCs are plugged into the wall outlet, they work just fine. They also work when connected to the ISP's wifi. But for security reasons I'd rather route them through this router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
doesn't help with security but does the router stay stable in access point mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Truth told I haven't used it in Access Point Mode because of the reduced functionality overall.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It does reduce functionality. But it its worth trying. Its a challenge when you have a shared internet setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reset the router and this time I set it up in Access Point Mode instead of Router Mode.
It seems stable. More stable than when I had it in Router Mode.
So I think perhaps this is not a hardware problem. But a conflict in how I set up the router in Router Mode.
I wonder if I had the same IP address on my router as on the ISP modem... And if that was the problem...
