Reply
Constant Restarts?
james_7000
Follower
Constant Restarts?
R7000 using firmware V1.0.7.6_1.1.99 restarts randomly after a few hours.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
ElaineM
NETGEAR Employee Retired
Re: Constant Restarts?
@james_7000 Have tried reinstalling the firmware? If you have not, try to reinstall then verify if you will experience the same thing. If you do, contact support for an RMA.
ElaineM
NETGEAR Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1614 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
