Reply
Highlighted
Control ethernet ports
Hi.
On my smart tv the wifi is pretty slow vs what I get on my cellphone and pc. My isp is 120/10 this is what I get from my devices except tv. I know the tv dont have the same network cards, I think it is max 100mbps.. but I get about 25/30 mbps , on the 5ghz and ethernet cable.
Some seems to have 65-70mbps.. my tv is samsung and they dont seem to have an answer. But someone told me that I could try to control the ethernet ports, reduce the bandwidth to help the tv, cause the tv can handle max 100 vs router which is wide open :-).. so according to him, on some firmwares or routers, we can choose for the ports : desactivate, 100mbps, 1000... etc.
Do you have an idea?
On my router I can use netgear firmware,voxel, open wrt or ddwrt
Thanks.
Btw you can check the pic, example of what I'm talking about.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 3
Highlighted
Guru
Re: Control ethernet ports
> [...] I get about 25/30 mbps , on the 5ghz and ethernet cable.
   "Get" how?
> [...] the tv can handle max 100 vs router which is wide open [...]
   What makes you think that the TV needs more than about 10Mb/s to do
its job?  Is there some actual problem which you are trying to solve, or
do you just want to see bigger speed numbers somewhere?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  I doubt that you'll
find anything about manually setting the speed of any Ethernet ports.
And, even if you could, I doubt that it would affect the TV.
Message 2 of 3
Highlighted
Hi.
I get the speed on my tv from speed test on the tv web browser.
And 10mbps it is not enough to stream 4k..
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 204 views
  • 0 kudos
  • 2 in conversation
Announcements
