Reply
Highlighted
Cooling solutions for R7000
Has anyone worked out a cooling solution for their R7000? My IR thermometer is putting the top of the case at 160deg F in a 77deg room. If the case is that hot.....
Message 1 of 7
Highlighted
Retired_Member
Not applicable
Re: Cooling solutions for R7000
Mine is running 100F in a 70F room. You have a problem.
Keep in mind that there are vents on the bottom. With almost every device like this, the first thing I do is attach some extra rubber feet to the bottom. My router has a good inch of clearance underneath it now and it's not hot at all.
Message 2 of 7
Highlighted
Virtuoso
No measurements here, but warm to the touch, just fine. No extra cooling needed.
How do you have your router mounted? Is it on a flat surface so that air can get underneath, and circulate around it? Normal air circulation cools my router just fine.
Message 3 of 7
Highlighted
I have it on a laptop cooling pad. Connected via USB.
Message 4 of 7
Highlighted
Retired_Member
Not applicable
try one of those USB fans.
Message 5 of 7
Highlighted
I replaced the stock cooling paste in the router with a thick layer of Artic Ceramique.
This is non conductive coolingpaste the produce better results then the stock cooling paste.
Message 6 of 7
Highlighted
Novice
I placed 4 adhesive backed rubber squares under each corner. These are at least 1/2" high and raised the unit up from the surface and seemed to improve airflow.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 6698 views
  • 0 kudos
  • 7 in conversation
Announcements
