Reply
Correct Fast Ethernet Cable but Slow Wifi Speed
ttk84
Firmware V1.0.4.12
Comcast Download from Modem (Comcast): Download: 180Mbps ; Upload 10 Mbps
Ethernet connect from the Router (Nighthawk X10): 178Mbps ; Upload 9Mbps
Wifi connect from the Router (Nighthawk X10): 20Mbps ; Upload 9Mbps (somehow upload speed still good)
How should I do with entenna? or what I need to do please help
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 3
antinode
Guru
Re: Correct Fast Ethernet Cable but Slow Wifi Speed
> Wifi connect from the Router (Nighthawk X10): [...]
   To _what_?  Have you any evidence that your bottleneck is the router,
and not your (unspecified) client device?  Which radio band are you
using, 2.4GHz or 5GHz?  Does some other device do better?  Does this
(unspecified) device do better with some other router?  Does changing
radio channels help?
> [...] Upload 9Mbps (somehow upload speed still good)
   If the wireless interface on your client device couldn't go faster
than, say, 20Mb/s, then that limit wouldn't affect your upload speed
(which your ISP caps at 10Mb/s?), but it would affect your download
speed (with its higher ISP speed limit).
   Blame assignment is job one.  Determine where the problem lies, and
_then_ start worrying about how to solve it.
Message 2 of 3
ttk84
I use both band but the 5GHz is better. It fave me 20 down and 9 up. The 2.4 Give me 3 down and 9 up.
I did change the channel but the problem is still.
What should I do?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 819 views
  • 0 kudos
  • 2 in conversation
Announcements
