Orbi WiFi 7 RBE973
Reply
Correct setting wireless selection
jimeeg
when using my phone at home to view Utube....phone showing connected to the 2.4G band...is this correct or should connection be to the 5G band ?
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 3
Accepted Solutions
Re: Correct setting wireless selection
Greetings,
This depends on your mobile device.  Does it have a 5Ghz radio?
If you are going for raw performance and the device has a 5Ghz radio, this band will give best performance from a speed perspective.
If you are looking for best broadcast range, the 2.4Ghz radio will perform best overall.
Message 2 of 3
All Replies
Greetings,
Message 2 of 3
jimeeg
Thank you for the help. I am using a samsung mobile phone to view UTube.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 816 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
