Orbi WiFi 7 RBE973
Reply
Covering Nighthawk 8
anth1225
Hi probably a dumb question but I just got my Nighthawk 8 and I'm concerned with it accumulating dust.  Basically I have a big family so someone is either on line or watching TV; it will probably be used about 90% of the time.
Would it be safe to cover it with a towel over the vents while I'm at work to prevent dust from ruining it or would that just cause it to overheat?
Thanks
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: Covering Nighthawk 8
> Hi probably a dumb question [...]
   Yeah, I'd say so.  Heat is probably a much greater threat than normal
household dust.  Add it to your regular vacuum-cleaning schedule, if
you're worried about it.  You have a soft brush attachment?
Message 2 of 3
All Replies
antinode
Guru
Message 2 of 3
anth1225
Yup guess I'll use that
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 803 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
