Orbi WiFi 7 RBE973
Reply
D7000 random disconnections after firmware update to V1.0.1.80_1.0.1
Retired_Member
Not applicable
Hello,
After updating the firmware to V1.0.1.80_1.0.1, something funky started happening on my router.
Every second day or so, the internet and wifi connections will drop.
All the lights on the front of the router stay on (including the Internet light), but every device in my house can no loger connect.
Strange thing is, it also won't connect via ethernet.
Even ping'ing the device gives me "PING: transmit failed. General failure"
I need to do a hard reset on the router to get connectivity back.... which wipes the log files so I can't see what might be happening to cause the issue.
Sometimes it'll have a good run and stay up for a few days, other times I'm resetting the router up 2 or 3 times a day.
At this point I'd revert to the old firmware if I could.
Can anyone tell me what might be the problem.
I could understand if another device was causing interferrence with the WiFi, but even the ethernet connection is going down.
Thanks!
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
Guru
Re: D7000 random disconnections after firmware update to V1.0.1.80_1.0.1
Have you tried simply downgrading a version of the firmware? maybe the version you're on causes issues.
Message 2 of 3
Guru
Please visit and post about this over in the DSL Modem forum:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Maybe more information to help you out there.
@Retired_Member wrote:
Hello,
Thanks!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 577 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
