Orbi WiFi 7 RBE973
Reply
DDNS Not Working
Edler
Follower
DDNS Not Working
Hello Netgear Comunity,
since today my Hostname XXX.mynetgear.com is not forwarded to the target IP adress.
Did anybody has the same Problem?
In NoIp.com the XXX.mynetgear.com Hostname is linked to the right taget IP-Adress. When testing another Hostname than XXX.mynetgear.com (like XXX.servegame.com) the forwarding works without any problem.
Are there any problems with the Netgear servers?
Thank you,
greetings Andi
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 3
Accepted Solutions
JamesGL
Master
Re: DDNS Not Working
Hi All,
This should be working now. Feel free to update here if still not working.
Message 3 of 3
All Replies
jd3203
I am having the same issue. When i key in the url to the ddns that i setup it hits a page that has a comment that states, "This Page Is Under Construction - Coming Soon!". Not sure what is going on. Too bad the stock firmware is limited when it comes to entering DDNS info.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 2 of 3
JamesGL
Master
Hi All,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1602 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
