Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
DHCP wan disconnect
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-02-08
03:58 AM
2019-02-08
03:58 AM
Hi
I’ve recently changed ISP’s and run into a bit of an issue
Previously , I was using ppoe and had no issues, but my new isp (Vodafone in Australia vdsl2) connects using ipoe
They issue a 1 hour lease and every hour I get a 5 second or so disconnect. Is there a setting I’m missing? On the latest firmware .70
Thanks
Thanks
Solved! Go to Solution.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
Labels:
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-02-09
03:58 AM
2019-02-09
03:58 AM
You are in the wrong forum. Modem Routers are covered here, https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers. Might have better luck posting there as others frequenting there might have some answers for you.
Message 3 of 3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-02-09
01:36 AM
2019-02-09
01:36 AM
Re: DHCP wan disconnect
Ok definitely a router specific issue, using the cheap isp supplied modem and it works fine, can’t get a full hour out of the Netgear
I turned off dos protection still no luck. Is there any Netgear support or way to send through logs?
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-02-09
03:58 AM
2019-02-09
03:58 AM
Message 3 of 3
Announcements
