Reply
DNS is grayed out when trying to use custom dns settings
MKOCT79
Follower
I'm trying to change my DNS settings on my nighthawk RAX48 and when I click use custom DNS settings the DNS is still Grayed out and I can't change it.
Message 1 of 3
Re: DNS is grayed out when trying to use custom dns settings
@MKOCT79 wrote:
I'm trying to change my DNS settings on my nighthawk RAX48 .....
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Guru
Are you doing it through the browser?
Trying through the app?
do you have a screen snip showing what you're trying to do?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 124 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
