Reply
DOS attack on my nighthawk x6 R8000 router. How can I block the listed IP's to help prevent attacks
kamikazeedragon
Luminary
Hey Guys.
     My router recently restarted.  When looking at the logs, I see that it got spammed from a series of ip's in a DOS attack.  Evidently it forced a router reboot.  I was able to perform a tracert on the ip and find where the attack came from but of course it ultimatley lead to a dead end.  I would like to do something to flag those ip's to prevent any traffic from them.  Is there a way to do that using the routers firewall?  Or is this something I will need another appliance for?  I included what I found in the event log below.
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: DOS attack on my nighthawk x6 R8000 router. How can I block the listed IP's to help prevent a...
You may want to make sure DOS protection is enabled.
https://kb.netgear.com/19957/What-does-Disable-Port-Scan-and-DoS-Protection-do
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 882 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
