× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Data Usage info unavailable at this time
Peterpoo123
I have a brand new Nighthawk M2, connected to Telstra.
The Data usage is not displaying. After an hour long 'conversation' with a Telstra robot/human, they say it's a Netgear issue that is work in progress.
Is this the case?
P.
Model: MR2100|Mobiler Router Nighthawk M2
Message 1 of 3
ArodiD
NETGEAR Expert
Re: Data Usage info unavailable at this time
Hi @Peterpoo123 ,
There are no issues with data usage that we are aware of.  I have just checked my Nighthawk M2 and it is displaying the data usage correctly.  Can you try rebooting the device to see if it comes back or do a factory reset on the unit.  Has there been any recent changes to your data plan?  Please also make sure the firmware is upto date by tapping Settings>Software>Check fo updates
Arodi
Message 2 of 3
Peterpoo123
Thanks for the reply.
As it turns out, the data usage started working this morning. It is a new data plan (but I've had the device and sim card for a week). The device had been working for a week, but just wasn't showing data usage. I guess it was just Telstra getting their act together.
Cheers.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2109 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
