- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Debrick unresponsive R7000 after flashing DD-WRT
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am a newbie. After flashing DD-WRT, I tried to restore factory firmware. I used the dd-wrt upgrade function to flash .chk file downloaded from official page. It was successfully installed. But after rebooting, I am unable to access to router interface from 192.168.1.1 anymore. I tried many other ips. Then I followed instructions of http://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP?cid=wmt_netgear_or... to restore firmware through TFTP. I can ping 192.168.1.1 by ethernet, but when uploading .chk file, TFTP client cannot get response from server. Any idea how to solve the problem? Thanks in advance.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you RESET the router AFTER flashing the NG f/w? Hold in the hidden RESET button for at least 30 seconds. See if that helps.
If you can PING 192.168.1.1 I'd think it isn't bricked? Does 192.168.1.1 show as the GATEWAY IP Address when you issue IPCONFIG /ALL in a CMD prompt?
Possibly 2 better places to ask about this would be:
http://www.dd-wrt.com/phpBB2/viewforum.php?f=1&sid=4be2bcb5a14c52f50f67322c5615e347
or
https://www.myopenrouter.com/forums/r7000-open-source-firmware
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
or
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Debrick unresponsive R7000 after flashing DD-WRT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly the same problem here with an R8500. any help out there?
