Reply
Device download speed not displayed
beaverHausen
None of my attached devices show download speed, only upload but I'm testing by streaming on all devices.
It's like Up and Down are the wrong way round, anyone else have this problem?2017-05-07 07.56.08.png
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 17
beaverHausen
Re: Device download speed not displayed
Just as an update to this, I believed my router to be faulty so swapped it at the store today for a new one.
I was happy to see figures in both Upload and Download for connected devices but, after an hour or so it's doing exactly the same thing.
Message 2 of 17
JamesGL
Master
Hi beaverHausen,
What is the firmware version of the router? Make sure it is updated.
What web browser did you use? Try using a different browser.
Message 3 of 17
beaverHausen
Hi
It's the latest firmware as shown in the photo.
Have tried different browsers with no result.
I have restored a backup config which is now working.
The backup was created before enabling traffic meter and remote access so I feel that one of these features somehow affects the device download display?
I've not turned either back on as I'm glad to have the info shown correctly.
Thanks for the iput though.
Message 4 of 17
JamesGL
Master
Hi beaverHausen,
Can you try to enable the traffic meter and remote access and see if it will still work.
Message 5 of 17
JamesGL
Master
Hi beaverHausen,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 6 of 17
beaverHausen
Hi
I enabled traffic monitor and set the monthly download limit that I receive from my ISP which is 750gb
After the router came back up, the devices in the attached devices list would only show a red bar in the upload and nothing in the download.
This is with devices streaming.
Message 7 of 17
beaverHausen
I have been doing further testing.
With Traffic monitor disabled, attached devices seem to display upload and download data correctly.
With Traffic monitor enabled, only the upload speed shows a red bar, this is with devices streamin/downloading data.
And now, when I turn Traffic monitor off, I get duplicates of my devices.
Any advice?
Message 8 of 17
JamesGL
Master
Hi beaverHausen,
Please check your inbox.
Message 9 of 17
IrvSp
Master
Interesting.
I'm on an R7000 and my display doesn't look ANYTHING like yours does? No speed shown, no choice of icon for the device?
I do see your language is AUTO, but mine is English.
I switched to Auto and then checked again, still do not have the same (yes, I'm on the newer flash, but I've never seen what you see?
Will take some time for my screen capture below to appear.
Message 10 of 17
LadolceMQT
I have the same issue.  I barely get any of my devices to show any activity.  Only had this router like 2 weeks.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 11 of 17
beaverHausen
Yeah it's annoying.
Went through some diagnostics with a netgear techie. They were unable to replicate my issue even with my config file that I sent over.
They offered to replace the unit but at a cost to me for P&P
Didn't have much faith that that would resolve the issue, just hoping a future firmware update will resolve.
Message 12 of 17
Baxter99
Having the exact same problem. Only difference is that turning remote management and traffic control off does not solve the problem.
Any ideas or fixes??
Message 13 of 17
beaverHausen
Nope, still not working for me.
Message 14 of 17
nairobiny
I'm having the exact same problem: upload speeds by device are showing but download speeds by device are all at zero. The meter at the top showing overall upload and download speed both show figures.
I've tried toggling 'Traffic monitoring' but it doesn't fix the problem. Remote monitoring is not set.
Message 15 of 17
beaverHausen
I downloaded a more recent firmware V1.0.9.32_10.2.34 hoping it would fix it but it just introduced a new problem, now I can't name my devices or give them an icon.
I don't think anyone at NetGear is doing anything about it
#sadface
Message 16 of 17
beaverHausen
Thought I'd add a bit more in case it helps anyone.
If I enable Traffic Meter from Advanced setup then it seems to have a problem in displaying live upload/download in attached devices, if I turn it off then I get information. See pic..
I'm still unable now to give my devices a meaningful name and/or icon, think I'll start looking for a different router this is really hacking me off...
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 4741 views
  • 0 kudos
  • 6 in conversation
Announcements
