Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Device light not on for AC 750 even though Ethernet is plugged in
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
08:44 AM
2021-08-01
08:44 AM
My wifi extender is plugged in and connected to the wifi. But when I try using it on my Xbox One, the device light does not seem to be on, even though an Ethernet cable is plugged in. I thought the Ethernet cable was the problem, but I bought a new one today and still the device light is not on. The problem only started occurring from yesterday when the device light just randomly turned off and wouldn’t turn on. It has been working for the past couple of years with no issue. Any advice on how to fix this? I tried searching which model I have, but I don’t see it on the options. I will attach a picture of the device.
Message 1 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
09:11 AM
2021-08-01
09:11 AM
Re: Device light not on for AC 750 even though Ethernet is plugged in
The label wll have the model number.
did you try other devices other than the xbox?
Did you try factory resetting and reinstalling.
If you reinstall, I'd highly recommend reinstalling using the installation assistant and not wps method.
Message 2 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
09:15 AM
2021-08-01
09:15 AM
How do I do the reinstallation? I’ve looked online how to, but I’m still a bit confused on how to.
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
09:16 AM
2021-08-01
09:16 AM
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
09:42 AM
2021-08-01
09:42 AM
I’ve tried factory resetting multiple times but it won’t work. I’ve pressed the factory reset button for 5 seconds and then let go. But after it restarts it automatically connects to my router
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
09:59 AM
2021-08-01
09:59 AM
I’ve reset it using factory reset and set it up using installation wizard, but now the router light is blinking
Message 6 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-08-01
11:00 AM
2021-08-01
11:00 AM
Is it working? are there issues with it?
How far from the router are you?
Have you tried changing the wifi channel?
Message 7 of 7
Announcements
