× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Device shown as offline
Ursusprimus
Follower
I haven't used my NAS for a while which I'd like to change now.
However, I can't access it. It's shown as offline  in ReadyCloud, although ''ve connected it ro my router via LAN. In the router it's listed.
Do you have any ideas what I could do?
Model: RN21200|ReadyNAS 212 Series 2- Bay (Diskless)
Message 1 of 3
Accepted Solutions
JohnCM_S
NETGEAR Employee Retired
Re: Device shown as offline
Hi Ursusprimus,
Welcome to the Community!
You can try first logging into the local admin page of the NAS by accessing https://<ReadyNAS IP address>/admin on your web browser. After logging in, you can go to the Cloud tab, then check the Internet and Service status. Both of them should have a green check.
You can also check if the ReadyCLOUD service is enabled when you go to the Cloud tab.
Regards,.
Message 2 of 3
All Replies
JohnCM_S
Hi Ursusprimus,
Regards,.
Message 2 of 3
Guru
Also, if you are running very old firmware you might need to update it (and also switch your readynas account over to SSO).
https://kb.netgear.com/30671/ReadyCLOUD-to-MyNETGEAR-Single-Sign-On-FAQ
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1209 views
  • 2 kudos
  • 3 in conversation
Announcements
