Orbi WiFi 7 RBE973
Reply
Devices not getting the speed that R700P is getting.
ejwtpt
Guide
R7000P  Nighthawk AC 2300 Smart WiFi dual band gigabit router not sending out the speeds it is getting. App says 200. Devices say 18
Upgraded my Spectrum cable internet from 15 MB's to 200. My Nighthawk app Speedtest shows I am getting around 190. All of my devices show that I am still only getting around 18. iMac (wired) iPhone, iPad. This is the same as before I upgraded. Where do I start troubleshooting. Must be some setting in the router I need to change.? Thanks
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 4
Accepted Solutions
Guru
Re: Devices not getting the speed that R700P is getting.
sounds like you might have some old qos settings running. I've heard of them being retained even after being disabled and a reboot.
Some have needed to factory reset and reinstall.
What firmware are you on?
What modem are you connecting to? (model)
Message 2 of 4
All Replies
Guru
Message 2 of 4
ejwtpt
Guide
Modem is d-link ccm-301
firmare on the router is v1.3.1.64_10.1.36
no updates available.
thanks. What should I do next?
Message 3 of 4
ejwtpt
Guide
Yes, it was qos. Spectrum tech was out for 2 hours and didn't have a clue. He finally gave up and said good luck. I did some more digging and discovered it was restraining the old slow qos settings. Did speed test within the router login interface and applied the new settings. Now getting speeds of around 190 down and 11 up. Thanks for your help.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1046 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
