Reply
Directions for connecting to computer
Fritzy65
Follower
I need directions for connecting to PC.
Model: R6100|AC1200 Dual Band Router
Message 1 of 2
Guru
Re: Directions for connecting to computer
We need more details than "I need directions for connecting to PC".
Are you trying to connect your pc to the R6100 that you have listed or trying to connect to something else?
How are you trying to connect? Wireless/wired?
If its wireless, what pc is it? does it have a preinstalled wireless card and if so, which one?
If its wired, plug one wire into router, other end into PC.
Where are you failing in this endeavor is more helpful to us than your initial statement.
Thanks
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 202 views
  • 0 kudos
  • 2 in conversation
Announcements
