Reply
Disable modem on AC1900/D7000V2
CliveP
Follower
Hi,
I have an AC1900/D7000V2 VDSL/ADSL Modem Router and now would like to use it just as a router. Is there a wau to reconfigue it to be able to use it as a wireless router within my existing network?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: Disable modem on AC1900/D7000V2
> [...] D7000V2 [...] Is there a wau to reconfigue it to be able to use
> it as a wireless router within my existing network? [...]
   Your "my existing network" comprises what, exactly?
   What is the actual problem which you are trying to solve?  Would you
like to extend your wireless-network coverage, or something else?  That
is, do you want to use the D7000v2 as a wireless access point (which
would be typical), or as a full-function _router_ (which would be
unusual), or what?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Use the Modem
Router as a WiFi Access Point".  (Or, if your really want to use it as a
router, "Set Up the Modem Router for Cable or Fiber Service".)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 437 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
