- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disable parental control without OpenDNS password
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I recently purchased this router second hand. I set it up, and everything works great, but I have noticed that it has enabled parental controls. I am able to log into routerlogin.net, but to disable the parental control I only get forwarded to log into OpenDNS. Since i purcased it second hand I dont know the login info. Is there no wat for mye to disable it from routerlogin.net or any other way? I dont want to contact the previous owners and ask them to login and disable it, so really want to try by myself first.
Appreciate all help!
Maria
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disable parental control without OpenDNS password
Please visit and post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Try a factory reset on the router by pressing the reset button for 10 seconds, then release. Use a wired PC and web browser to setup the router again from scratch.
Good Luck.
