Reply
Disable port forwarding
jackwy
Follower
Hi, I am a first time user for R7800 model.  I added some port forwarding rules but decided to not use them right away.  Is there any way to disable all the rules without deleting them?
Please advise me.  Thanks!
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 2
Re: Disable port forwarding
You could try creating a backup of your configuration in the usual way.
See page 106 of the manual:
R7800 | Product | Support | NETGEAR
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3039 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
