- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Disapearing Port Forwarding Setting! What is the solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RAXE500 Keeps dropping the Port Forwarding setting. I have 2 telnet servers running and a FTP server. Randomly they will just stop working for no reason. Then when I go into the settings for port forwarding they will be GONE. If I try to add them again it will tell me they are already there even though you cannot see them or they do not work. I have seen YEARS of people with the same problem. For me I have to reload a previous configuration I saved to disk. But this is NOT a solution. I paid close to $500 for this thing and it just does not work with no solution in sight. Has anyone come up with a fix for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Disapearing Port Forwarding Setting! What is the solution.
How are you configuring the PF rules?
Have you disabled uPnP prior to setting up the PF rules?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello and thank you for the help.
What Firmware version is currently loaded? Firmware Version V1.0.8.70_2.0.36 It has been going on the last few versions also.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It has worked with my last 2 linksys routers. It is only affected by this router.
How are you configuring the PF rules? With the normal port forwarding tab.
Have you disabled uPnP prior to setting up the PF rules? No.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is what the screen turns into. The rules are there and working right now. You just cannot see them to edit them or access them. Next pic is what happens when you try to add or edit them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's port forward rule do you use ?
one rule for ftp, two rules for telnet ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? It has worked with my last 2 linksys routers. It is only affected by this router. <So What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Have you disabled uPnP prior to setting up the PF rules? No. <This should be DISABLED prior to setting up PF rules.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Answer Hitron #en2251. This problem has existed with 2 different modems. If I set up my old LInksys router everything works fine.
I disabled it and it still does not work as it should.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just had to reload the setting for it to work again.
I wanted to upgrade to 6e. So I spent $500 on this router, now going to spend $350 on a LInksys. I have no idea why this is doing this over and over and I have not heard a peep from my support ticket.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I added a few pictures. FTP, 2 Telnet, and one for OPEN VPN
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @SniperStorm ,
Does it show correctly in port forwarding page for now ?
If yes, could you share the screenshot ?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone found an answer to this? I have the same issue where my PF rules do not show up in the list and they don't seem to be working. I am trying to PF a standard TCP port with a custom service rule.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I previously had a Nighthawk 7000 and the port forwarding worked fine. I tried disabling the uPnP as well and it did not fix anything. Very frustrating as this was not a cheap router and you would think that the port forwarding would work especially since people purchase this for gaming purposes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
