Reply
Does NETGEAR Nighthawk X10 R9000 support several ssids and b/g/n clients?
POMATu
Follower
Hi,
Does it support virtual isolated APs and clients with old wifi modules (b/g/n)?
Thanks
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Guru
Re: Does NETGEAR Nighthawk X10 R9000 support several ssids and b/g/n clients?
You can create guest networks that have their own SSIDs.  There are settings for network isolation on the guest networks.
It certainly works with N clients, and should work with G.  B ought to work if you have security turned off (or if the client supports WPA).   But it's been a very long time since I've tried connecting a B client to anything.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2666 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
