Discussion stats
  • 1 reply
  • 974 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Does The nighthawk R7000 have NAT options
So i’m Thinking about buying a Nighthawk R7000, but i’m Just wondering if it has the option to choose what kind of NAT type I want.
Does anybody have experience with this product or know if it has this option?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Highlighted
Re: Does The nighthawk R7000 have NAT options
A good place to start might be the manuals for the devices you are considering. That should explain what you can change on the NAT front.
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
There is a manual for a newer model, the R7000P, somewhere at the end of this link:
>>> R7000P | Product | Support | NETGEAR <<<
From what I have read, the main difference between the two seems to be the main chipset, Broadcom versus Intel.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
