Reply
Does it matter if i use a Nighthawk R7300DST without the DST and with a AC1900 Wifi Range Extender ?
I bought the AC1900 wifi range extender because i thought it was a better solution for my wifi instead of the smaller device that is the DST?
Do i have to use the DST in order to make my wifi work better or can i keep using the wifi range extender?
Message 1 of 3
NETGEAR Moderator
Re: Does it matter if i use a Nighthawk R7300DST without the DST and with a AC1900 Wifi Range Ext...
You should be able to use it without the DST.
DarrenM
Message 2 of 3
Guru
Re: Does it matter if i use a Nighthawk R7300DST without the DST and with a AC1900 Wifi Range Extend
like @DarrenM says, you can use the extender without issues.
I'd check into trying the powerline since you already have it. You might be surprised. the downfall to using a wireless extender is that it take roughly a 50% bandwidth hit because it has to recieve and retransmit. The powerline device doesn't have that downfall. Plus extenders increase latency.
CM2000-> Arris AX11000 W31-> GS716v2-> WAX***-AP
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 127 views
  • 0 kudos
  • 3 in conversation
Announcements
