Orbi WiFi 7 RBE973
Reply
Does performing a reboot helps with corrupted firmware? R7000
AmbarReatio
Hi, I tried to instal the new firmware and for some reason it didn't work. Now the power light is blinking and doesn't want to turn back on.
Would a factory reset also reinstal the original firmware?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Accepted Solutions
myersw
Master
Re: Does performing a reboot helps with corrupted firmware? R7000
No a reset will not reinstall the orginal firmware. Reset only clears the settings you have made. In your case you are probably a candidate for doing a tftp recovery.  This is one example of how to to a tftp
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Message 2 of 3
All Replies
myersw
Master
Message 2 of 3
AmbarReatio
Thanks, have been reading about the TFTP solution. Hope this will work.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 860 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
