Reply
Downloading problem
jonathancedat11
Follower
Downloading problem
I’m having problems with my connection on my Xbox, it wont let me down load any game or update them. I did all the basic things like turn off the router, and resetting it as well I don’t know what to do. I had this router from may of this year.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Guru
Re: Downloading problem
Many times people use their isp's modem which has a router integrated into it and it creates a double nat situation. Many services (xbox, apple, etc) fail to download/update in these situations.
https://kb.netgear.com/30186/What-is-Double-NAT
What modem are you using? (model number)
Waht firmware is on your router?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 706 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
