Reply
Dropped wired and wifi connections in unknown intervals
dannydev
When I have first installed the router, with original firmware it came with, I had NO issues. After 2nd or so firmware update all my devices, wired or not, keep dropping connections!
My devices don't show connection as dropped, but throughput gets to a halt. Nothing happens, there seems to be no connection and that status lasts for like 10-30 seconds, after which everything resumes as normal.
I've tested my IPS modem at the same time and it is constantly available on the same machine that looses connection that is going trough R7000.
This is my setup in the picture linked, but I doubt it has anything to do with that.
Message 1 of 3
Retired_Member
Not applicable
Re: Dropped wired and wifi connections in unknown intervals
Use R7000 as AP
Message 2 of 3
dannydev
My ISP router is unreliable to govern the home network. It is often reset to defaults, reset at all... And it is actually unsecure.
Why do you think that would solve the problem?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2038 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
