- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6200V2 Connects to phone when EX6200V2 powers up but not afterwards no IP address
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the EX6200V2 extender 4 years ago and has worked very well until now. When I power up the Phone in the morning, the phone tries to connect to the extended wifi but message Couldn't get IP address appears. If I power off the EX6200V2 then on again, I get an connection. If I power off the phone or move to the main wifi - I cant get a connection again - Can't get an IP address. If I power off the extender and I get a connection. I have done two factory resets and has the latest firmware installed as a result of the factory resets. I am not sure whether to buy a new extender. Any help appreciated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6200V2 Connects to phone when EX6200V2 powers up but not afterwards no IP address
What router is it connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router is a Spark (My ISP Provider) Model no VRV9517UWAC34-A-SP. The router has been replaced and the problem remains. Dave
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you setup the ex6200 using wps or using the installation assistant?
have you tried disabling bandsteering on the spart router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the factory reset I used off the web the instructions. Whilst i wont write it all in summary. Placed router near the WiFi router. Powered up. Disconnect my PC from the Interent and typed in New Extender setup and I followed the instuctions. Entered the WIFI name. Used Netware Genie. No I haven't tried disabling bandsteering on the spart router. I will try this. I haven't done this before but I will have a go. I left my phone power up and connected last night and the wifi connection is still connected. Appreciate your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just set off Bandsteering and tried. No chnage - I could not connect. Should I set bandsteering back on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can turn it back on.
Have you set it with a static ip address in the VRV9517
- Mark as New
- Bookmark
- Subscribe
- Permalink
No I am not sure how to do this. I will find out and have a go. Dave.
